wastegate spring diameter ?
  • Nik0las
    • 1345
    • Country: Bulgaria
    I will need better spring for my WG what was the diameter 38mm?
    what you thing about that:
    http://www.ebay.com/itm/17-8-psi-SPR...item4ceeeac87a
    Can I find something stronger?
    I guess you missed this recent thread in which somebody measured the WG spring as 38.5 mm:
    • Nik0las
      • 1345
      • Country: Bulgaria
      well I need something for 500hp+ setup. My boost control can hold the boost with the stock spring. So I will need something stronger to hold arround 2 bar with the help of the bost control.
        All you need to do is change the boost wiring so you use the top and bottom chamber either via a 4 port or 3 port solenoid
        • Nik0las
          • 1345
          • Country: Bulgaria
          I'm not sure what you mean my 3 port solenoid is connected to the both chambers but the presure which is making is not strong enough to hold 2bar presure. It's making 1.8 peak and then it dropped back to 1.6bar
          However I'm using greddy spec II bost control.
