BOV controller
  • s2_bo
    • Oct 2005
    • 6067
    BOV controller
    I saw the other day that Turbosmart have developed a BOV controller. See here
    Effectively just a controller that uses a solenoid to adjust when and how much air is going to the BOV/DV cap.
    I wonder if any of our resident mappers could code an adjustable controller like this in to an ecu remap.
    Could be used to open the BOV/DV early, not as far or late to give a bit of compressor stall when you want to impress your mates
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    This system is in effect as standard on the S4 cars and it's one of the 1st things to be deleted by tuners and home modders
    • s2_bo
      • Oct 2005
      • 6067
      ohh ok, ill get my coat then..
      91 S2 coupé - RIP
        I actually was interested in well when I 1st saw it, had the same idea controlling via vems
        • prj
          • Mar 2010
          • 6308
          Huh???
            The bi-turbo's control the dump valve via the ecu and N249 valve. They perform the N249 delete
            • prj
              • Mar 2010
              • 6308
              Ah yes, I thought you were talking about 2.2T
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Yup. Jamo is correct. It's the same on 1.8Ts. I did that years ago on the A3. It comes with a small vacuum reservoir so that the ECU can operate the DV when it likes. Deleting allows you to throw that and a load of check valves and hose in the bin.
                So that kit would be a good waste of money IMHO.
                The S3 also has that damn SAI and N112 crap I still need to get around to ripping off.
                SS
                • prj
                  • Mar 2010
                  • 6308
                  N249 supposedly helps fuel economy by reducing pumping losses though?
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    Supposedly. I can see the theory. But I can still get up to 45mpg (<6.3L) from my A3 1.8Tq on a trip.
                    As far as I can tell it's a lot of unnecessary junk under the bonnet.
                    SS
