Car has been flying recently until I took it out yesterday and discovered that it didnt want to boost above 6psi,so I took that at being mechanical boost only.
Further on my journey I had the temp/coolant symbol start beeping away at me.Oil and water temp were fine,no coolant leaks,although the water temp was right down but it was -10 here.
got home to have a look,temp would rise whilst car was sitting and idling and fan would kick in,still flashing temp symbol.
Anyway took out mfts and checked wiring and put back in.temp warning then dissapeard,but still no boost.
Does the ABY store a code in the ecu to limit boost?I thought the 3B was more affected by this.Mine has 3 pin plug,pulled motor fuses for a few mins to clear any codes but still not boosting.
Have checked everything else and I mean everything,WGFV,maf,hoses etc etc.
Is my Mfts knackerd and limiting boost or can someone else point me in another direction
