I have seen pic's and artical's on 2bennett.com where they have sucessfully fitted Rs2 airbox into a urquattro or 2. Now i don't think there is room to fit one straight in there without modifying the inner wing or the airbox as a standard s2 won't fit. Anyone have any idea how this can be achived? The sound of an RS2 airbox in a UR wound be a great solution. Would it be a case of modifying the bottom haif of the airbox?
RS2 airbox into urquattro?
Got an email back from 2bennett this mornig. Seam they just modify the airbox and keep the original inner wing. Would love to see what they change.
"Yes we offer the RS2 air box modified to fit with your stock/OEM apron. Cost for the airbox ready to bolt in is $1195."Last edited by dirtybarry; 29 February 2012, 11:42.1986 urquattro 20v 3b
I have an aby one on mine. As the factory cut the inner wing to mount the rr box I did the same.
Surely moding the box will make it tiny like the wr. Seems a bit pointless and very expensive!Rob..
87 UR 20v ABY
97 S6 Avant
The 3B filter box is a fairly straightforward fit and used it on mine for last 3 years, however the filter size in these is the same as that used on the Normally Aspirated KV 136bhp engine and a bit restrictive once even a re-map is carried out.
The ABY/RS2 definately will not fit without mods. I was going to fit the RR quattro airbox until I found they were NLA and daft prices 2nd hand so fitted my own solution. Though the only downside is that you can now hear every chirp, whine and whistle from the turbo
Pics below are of a mates solution with RR box and mine.
My new install.
1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remap
Originally posted by dirtybarry View PostGot an email back from 2bennett this mornig. Seam they just modify the airbox and keep the original inner wing. Would love to see what they change.
Originally posted by GT500 View PostI have an aby one on mine. As the factory cut the inner wing to mount the rr box I did the same.
RS2 Airbox in Urquattro
Hi All,
I did use a typ89 inner wing and adjusted the RS2 Airbox.
Here are some pic's
