Hi,
Just a headsup really and to see if im alone...I've just broken another IAT sensor in the end of the wagner intake.
This is the third one since the install. Thought i'd slipped with a spanner and maybe damaged the first. Then the second i put down to unlucky but after a heavy launch last night the idle went up to 1100 and wouldn't come down. I had a look today and spotted/heard it. Im guessing the engine moves in a certain way that catches something there.
I have 034 street density gear and motor mounts and poly snub less than 10,000 miles ago so movement must be v.Minimal.
Going to blank it off and fit a bung and sensor in the IC outlet. Not ideal but its all wagner silicon hose from ic to tb and i'd rather not hack it up.
