Same Side IC
  • BorisShakhov
    • Feb 2009
    • 224
    • Country: Russian Federation
    Same Side IC
    Does anybody have links to projects or pictures where same side (in/out) IC installed?
    For example
    Are there any advantages of using them?
    Does it make any sense to replace oem bar space with IC surface?
    That's an awful design it should be like this
    • BorisShakhov
      • Feb 2009
      • 224
      I have 2 pictures
      I think it can`t hide under the s2 bumper...
        That one is slightly better as the inlet and outlet sections are divided and not joined like the IC in the 1st pic
        • andy10v
          • 5996
          Chris has one in his 200
          ************************************************************************************************************************************************************************************ This space is now going to be used as a working index of the build's various phases. I'll update with milestones...
          And a interesting vertical flow discussion, the biggest drop in temp occurs within the first few inches apparently.
          Yes, flow is only one part of it, but vertical also has more surface area for cooling so its the best of both worlds. I'm just throwing it out there. Regardless, you guys have huge freakin IC's. Scary stuff lol.
          Sold ABY-stock
          • BorisShakhov
            • Feb 2009
            • 224
            http://www.motorgeek.com/viewtopic.p...lit=treadstone
            Thanks!!
