Is £170 good for a new maff and is it the same as Rs2 maff?
S2 maff
Originally posted by bilko0795 View PostIs £170 good for a new maff and is it the same as Rs2 maff?
http://members.shaw.ca/speedtek/UrS%...ice%20Map.html
3B/AAN/ABY on the left, ADU on the right:
IF i remember correctly the air vents/grills are bigger on rs2 maf, look like a waffle.
the s2 maf is much more restricted with smaller holes for the air to get in, so definitely not the same aesthetically, but function the same mechanically.''I'm 999 thou' short of a mill!''
Originally posted by Biggss2 View Postat least i think they do, Dave would know
Here are graphs of the AAN and RS2 OE MAF output voltages at different RPMs on an AAN engine:
Originally posted by UrS4boy View Postprj (dmitri) (and Paul N) knows even better. What I know, is they are very close electrically but you need to remove the metal screens to get them to flow in a similar fashion.
The difference on that graph is likely because not two brand new units were compared and because they are within a 3% error margin anyway.
That graph to me looks like they used an AAN maf with some miles on and a brand new ADU MAF.
Originally posted by prj View PostI can confirm from factory data now, that they are completely identical electrically. The difference on that graph is likely because not two brand new units were compared and because they are within a 3% error margin anyway.
That graph to me looks like they used an AAN maf with some miles on and a brand new ADU MAF.RS2'd 93 UrS4 5 spd sedan
Originally posted by diogocartier View PostCan I use RS2 maff on a S2?
It will fit, but I don't know if it will work on a proper way..
Click on the G70 MAF label (lower left) in this diagram to get more MAF info:
http://members.shaw.ca/speedtek/UrS%...ice%20Map.html (all the other labels are live too)RS2'd 93 UrS4 5 spd sedan
