Good damn this tubular manifold
  • audiman
    • 4827
    Tried to fit this last night, but what a job, i got all the turbo oil/water lines sorted and everything is bolted up, minus the downpipe which has to be made. Dont fancy running it until thats one incase it torches the car!!!
    Only problem i have is where is the MAF going to go, i have about 2.5" clearance behind the headlight and thats it. Plus i have AC and std intake setup
    Heres a few pics of it so far anyway.
    If you have some ideas of what to do then let me know
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • audiman
    • 4827
    And
    Audi UR Quattro
    • audiman
      • 4827
      and this one
      Audi UR Quattro
      • audiman
        • 4827
        and this
        Audi UR Quattro
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Hmmm.. A tricky one.
          Does anyone have any experience of using the MAF after the turbo? Like after the IC.
          I think with Tom’s huge IC, air temps wouldn’t be too much of a problem.
          Just an idea.
          SS
          • audiman
            • 4827
            LOL, i can see my mashed oil cooler in the last photo, damn that hedge accident
            Audi UR Quattro
            • S2 Ant
              • 3682
              thats a long way forward isnt it!! :S
              Ant
              2011 Kawasaki Z1000
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Nice coloured pipe fitting though!
                SS
                • audiman
                  • 4827
                  I know, thats what is annoying me. And there is no way i can fit a MAF there!! May have to look into changing ECU system Which i cant afford at the moment.
                  Audi UR Quattro
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    Tesco loan?!!
                    SS
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      Here’s a picture of my homemade intake pipe during development.
                      I think you had a similar set up, Tom.
                      I kept the pipe the same size as the inducer bore on the first bend, and then slowly swept it to the MAF bore.
                      It looks pretty tight on yours now. I found my ellipsoid headlight made the problem worse, as it is deeper than the original headlight.
                      SS
                      • sorens2
                        • 241
                        • Country: Denmark
                        Hi Audiman
                        Move the MAF on the other side of the IC. I did that and it runs very nice like that. Only problem is that you have to do some small adjustment in the ECU. But I would do that, especially with a bigger turbo like that.
                        Søren S2
                        Audi RS4 LO550
                        BTG 8:08
                        www.fredslunds.dk
                        • audiman
                          • 4827
                          Got any pics of where you placed it?? Also how do you make it not leak boost?? Its only plastic so you cant do the hose clip real tight, surely it will leak?
                          Audi UR Quattro
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            I think as long as the pipework isn’t wobbling about it should be ok.
                            Especially with the pipe clips that you are using. They provide a good even spread of the load on the pipe.
                            You could always strap the pipes together, to make sure they don’t blow off, if you’re using mega boost!
                            SS
                            • Markus
                              • 184
                              This is from Zaphod's car on irry.com:
                              Markus
                              '94 Kristallsilber-metallic S2 Avant.
