ss exhaust repair question
  • geryS2
    • May 2006
    • 814
    • Home: Belgium Current: Portugal
    ok, here is the problem,
    well i got a full 3" exhaust, but this part seems in steel,
    does anyone got the same system, or is it normally to be done fully in stainless steel ?
    cheers
    S2 's and oldtimers
  • geryS2
    • May 2006
    • 814
    here is it when it was new
    S2 's and oldtimers
    • AndyP
      • 6049
      The flexi's are generally made from mild steel, just cut it out and weld in a new one. Make sure you use the right filler for welding mild steel to stainless steel, you need a 309 filler rod.
      • geryS2
        • May 2006
        • 814
        is it possible to put a flexi in stainless steel ?
        cause to do this job , it s needed to get the full exhaust out, do not want to do it every 5 years
        thanks for info
        S2 's and oldtimers
        • AndyP
          • 6049
          I don't think you can get them made from 100% stainless, the ribbed part that has rusted through in your first pic needs to be made from mild steel, stainless would work harden and fracture if used to make this part.
          • geryS2
            • May 2006
            • 814
            ok thanks again for info,
            another question , where can we buy this part ?
            S2 's and oldtimers
            • geryS2
              • May 2006
              • 814
              http://www.befr.ebay.be/itm/Stainles...item335b2bf94d
              is this ok ? (on thebay)
              S2 's and oldtimers
              • AndyP
                • 6049
                Yes MIJ are a good supplier
                • quattro84
                  • Mar 2006
                  • 947
                  Best ones around but far more expensive are from Witzenmann, which some models make use of an inner liner that makes it much more quiet and durable.
                  Will have a look @ work if i can source a supplier, i do think they have a Belgian resident factory/shop.
                  • geryS2
                    • May 2006
                    • 814
                    thanks big for that info, i was a bit surprised that this one lasted only 4-5 years, so a more durable is much welcome !
                    cheers ( btw i found that rear red panel, but very expensive)
                    S2 's and oldtimers
