"induction kits"
  • dan_b
    • Sep 2003
    • 3670
    "induction kits"
    Just purely out of academic interest (yeah, right ), what options are there for improving the air induction on the S2?
    Are the usual "sports panel filters", Cone induction thingies, and cold air feed type pipe jobbies still available off-the-shelf, or are they very much custom jobs now?
    Is there much point cost/benefit wise, apart from a noisier rasping sucking sound?
  • Dr H
    • 1175
    Sports panel filters are readily available from all sorts of places as the S2 shares its filter with lots of other VW and Audis.
      • 12431
      only problem with the S2 is if you go for a cone type induction kit there is a problem with heatsoak to it if you dont make a shield or have it located in the right place.
      And a few people have had problems with OILY MAF's when using the oiled K&N type filters.
      Personally on a standard car i would just fit a better panel filter but on upgrading engine think it is more worthwhile fitting a cone filter in there properly
        • 12431
        Doesnt look a bad idea this intake pipe.
        Just a matter of finding a good route up behind the headlight, sure there must be a good way of doing this, esp since mark has mounted his Air filter here.
          • 12431
          Are air filters worthy
          Judging by reading this article about the intake system of a US S4 (uk S6) it would seem that the air filter is one of the least restrictive parts of the system
          • Vagsport
            • 533
            I used two different inductions on my car, first K&N, then Pipercross. I had these for under a year, and went through 2 MAF's. I would stick to a decent panel filter, seems MAF's are not only sensitive to oil mist, but also the car seems to run leaner at top end (more air on current fuelling). :mad:
            • MikQuattro
              • 769
              • Home: England Current: United States
              I disagree with the heat problem. The air is going to go thru the intercooler anyway, I don't think heat shields make a lick of difference. In fact, I think the real heat problem for incoming air is the metal tube which runs along the nice hot intake where the air has plenty of time to heat up on it's way to the intake. That's the heat problem, not the air filter. Open that thing up and let it breathe, let it get as much air as it wants....
              Painfully said goodbye to my baby....
              2001 A4
              Silver with black leather, Symphony, sport package, S4 bumper and wheels
              • Mihnea
                • 1288
                Mik, I have to disagree, I've measured intake air temps in both cases and a badly insulated induction kit increases intake air temps by at least 5-10 degrees C, which means that the engine will ping a lot easier. The air goes indeed through the intercooler, but on a chipped car where the turbo is already at the efficiency limits, the intercooler isn't of great help unfortunately.... A good heatshield though, will make for identical intake air temps as compared to a stock airfilter, but with improved breathing. Another problem is that the stock airfilter box has a pipe before the air enters the MAF, which is meant to "straighten" airflow, well, if you take that one out, the MAF might suffer more from turbulences coming directly from the air filter, I and several other people have unfortunately BTDT...
                www.MRCTuning.com
                info@MRCTuning.com
                Workshop Directions
                • porkkis
                  • 1994
                  There is one clear advantage: the original air box is so sound absorbing that you really can't hear the by-pass, but with cone type you can get the sound out of it
                  • s2driveruk
                    • 12696
                    Had a K&N cone on mine for over 18months and not had any problems with MAFs, oil mist etc etc the only thing i do notice is that when the engine is very hot it does bog down when you pull away, once positive airflow through the front of the car is achieved then the problem disappears and everything is ok.
                    I have fashioned a makeshift heat shield and I have noticed only a little bit of difference and to be honest even that gets bloody hot. I think placing a cone where Mark H has his is the only sensible location to get the benefit of true cold air.
                    Yeah - and the 'sneeze' on gearshifts is cool!!!
                    David
                    1992 3b S2 Coupe
                    • MikQuattro
                      • 769
                      Mihnea, thanks for the info, I wasn't taking the chipped performance into account. I can see how a chipped car would be affected by any variance in airflow or heat. I wonder how much difference there would be if you added a heat shield for the induction kit and an additional shield for the air piping up to the intake?
                      Thanks again for the input!
                      2001 A4
                      • Graham
                        • 1622
                        With the intake that low dont you have problems with water ingression and if you hit a decent puddle :eek2: wouldnt the car suck up the puddle, what about a bonnet vent and a piece of ducting that would take air to the underside of the standard airbox, not a big noddy max power spesh, but a nice little scoop right above the airbox, where the air is at high pressure as it has just been forced up the front of the car and over the bonnet?
                        Graham
                          • 12431
                          whilst ive had my car apart the last few days it would be quite easy to install an extra intake pipe up behind headlight for the standard air box with a pipe running from oil cooler duct to plastic trim behind headlight which should allow more cool air upto the air box.
                          Will have to wait until bumper is off again to do that.
                          • audiman
                            • 4827
                            Am I right in saying that a stock car will not run properly using a cone filter? I have experienced this myself until Mr. Nugent did some custom mapping.
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • s2driveruk
                              • 12696
                              Tom,
                              Was running my car (in stock form) for over a year before home fries. Noooooooooo problems at all.
                              Cheers,
                              David
                              1992 3b S2 Coupe
