ABY manifold value
  • vag_nutter
    • Sep 2009
    • 164
    • Country: New Zealand
    ABY manifold value
    I have an aan that im fitting to my typ85 90, and as we all know the aan manifold doest leave much room for the radiator, so Im looking at 2 options, modify the aan manifold or import an aby, so I would like to know the going rate for an aby manifold, water pipe and fuel rail and if possible a price on shipping to New Zealand, but im guessing it will probably work out cheaper to have my aan manifold cut up and shift the throttle body
  • Rusty
    • 18953
    Modify the AAN one as there are quite a few things you'll need to reroute and modify, plus you'll have the longer inlet tract we all dream of removing
    • Ian Simmonds
      • Jun 2005
      • 2858
      On the Rallywreck we kept the AAN inlet track unmodified and worked our way around that, there's enough room for a custom made rad and, if additional cooling is needed, we lower mounted the Intercooler so the Aux rad space is still available.
      This is the large Kenlow fan we fitted (on top of the old rad for size reference only).
      93 MTMS2 Avant
