Difference aby/rs2 intercooler?
  • defcon
    • Apr 2007
    • 27
    • Country: Norway
    Is there any difference between the rs2 and the aby intercooler?
    RS2 must be thicker/longer (others will tell us). S2 (coupe, sedan and avant) charge air cooler = 8A0145805B, RS2 = 8A0145805C
    Corresponding front cross members are different too.
    S2 = 8A0805853B, RS2 = 8A0805853D
    • andyg plym
      • Nov 2006
      • 4646
      rs2 is wider by about 2 to 3 inches.
      fitted mine a few days ago
      • defcon
        • Apr 2007
        • 27
        • Country: Norway
        Is there any clearance problems with org S2 bumper? I struggle to fit the lower plastic vents in the bumper. I don't know which cooler I have.
        • andyg plym
          • Nov 2006
          • 4646
          I use a reiger rs2 bumper and its a bit tight just like a standard oe s2 bumper but you should not need to cut it.
          • mcandmar
            • Apr 2004
            • 5118
            Piccy attached..
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • andyg plym
              • Nov 2006
              • 4646
              great picture!
              obviously need to remove the old 2 holed bracket,and mount another on the x member.i was lucky and obtained a wagner bracket,drilled 2 holes with the cordless drill (metal is thin) and bolted it on,job done
              • simon20vq
                • Dec 2010
                • 1379
                DEFCON, yes rs2 intercooler fouls on the offside vent. I trimmed the clips to make it fit flush.
                • defcon
                  • Apr 2007
                  • 27
                  • Country: Norway
                  Thank you all for answering. On the plus side I have a RS2 cooler, on the down side I have to modify the hard-to-get vents.
                    Originally posted by mcandmar
                    Piccy attached..
                    I get it that the RS2 intercooler is on the bottom, with the S2 intercooler above it. However, I can't tell if that is the RS2 or S2 crossmember. (I think its the RS2??)
                      Looks like an S2 crossmember to me ?
                      • mcandmar
                        • Apr 2004
                        • 5118
                        S2, you can see the right hand mount lines up. Forgot to take a picture after i modified it for the RS2 one.
                          Okay, thanks. I see that now. Where is the <slaps forehead> icon?
                          • simon20vq
                            • Dec 2010
                            • 1379
                            result has the car been modified elsewhere, turbo, ecu, n75???
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              all of 3 are the same in dimessions except the lenght
                              3B is 40cm
                              ABY is 43cm
                              RS2 is 50cm
