Wagner intake manifold questions
  • adam g
    • Feb 2007
    • 445
    Originally posted by Pat D
    I thought the factory pressure was 4 bar? I can't remember, might be 3, but I'm sure there are different fixed pressure regulators that fit the factory rail? Was this the reason for mentioning changing to an aftermarket regulator?
    The only thing I want to add is an electric pressure sender so I can mount an internal pressure gauge.
    Factory fuel pressure is typically 40 psi so closer to 3 bar.
    • andy10v
      • 5996
      There are different fpr
      3B is 3 bar
      7A is 4 bar
      ABY, AAN is 4 bar
      ADU is 3.8 bar
      Sold ABY-stock
      • adam g
        • Feb 2007
        • 445
        Actually I forgot to add on the 1 bar due to atmosphere so 40psi is closer to 4
