OK, so a few months back I bought an ABY cross member and intercooler off another forum member. I stuffed it away in a box and thought nothing more about it.
By chance it was out of the box with some other parts when Pete (Acidburn) popped round. He commented that it didn't look like an ABY intercooler and might be an RS2 one.
Great I thought, maybe I've got a bargain there - so I looked into it.
First of all I check the part number on it which corresponds to an ABY part number: 8A0 145 805 B.
But then I looked at some pictures of ABY coolers and sure enough mine looks different - its longer and has less rows - 10 vs 15 that appear on an ABY cooler.
I measured the core which seems to be larger than an ABY cooler too
500 x 180 x 64mm
Interestingly it seems to be more like a bar & plate construction than a tube & fin
The cross member looks more like an RS2 one with the bracket off to one side:
Compared to an ABY cooler and RS2 cooler it doesn't look like either
Its longer than an ABY
But the end tank is not the same as an RS2
The cross member has been damaged and repaired at some point which made me wonder if the intercooler had been damaged had the core replaced maybe? But the welds look factory to me.
Can anyone help me solve this?
500 x 180 x 64mm
