V6 fuel pipe size please
  • bluequattro
    • 2960
    What size are the pipes under car for fuel?
    8mm?
    Mrs has just run over a box of my school books n ripped the fuel pipe!
    Car only passed mot yesterday after brake pipes n bushes!
  • Nuvo
    • Nov 2003
    • 3827
    8mm.
    • bluequattro
      • 2960
      • fourringsrus
        • Oct 2009
        • 239
        On my v6 ABC coupe I managed to repair successfully with hose and clamps quite cheaply if you cant get access to the correct part which were quite costly if I remember at around £70 front to back each.
        • bluequattro
          • 2960
          Broken right under the shielding by the bulkhead
          Covered in rust n dirt so no wonder really
          My cheapo mechanic fixing tomoz
          Worth £20 for him lie in the snow n ice instead of me!
          • fourringsrus
            • Oct 2009
            • 239
            Keep in mind that the middle line is only for the carbon canister or whatever it is called, so not worth poncing about with.
            If it is gone at the bulkhead you'll probably struggle to work without breaking it further down the line at each and every clamping area, where it it will be rotten inside the rubber boots.
            Good luck
            Stuart
