Hi guys,
Lately I have been hearing a loud noise which as first I thought was a knocking noise but since pulling apart the intake side I have located the noise coming from the return line from the crank ventilation. (Excuse my terminology)
It is sounding like sucking or gurgling coming from the return line and when I cover it with my hand(with the engine running) the noise stops.
The car is fitted with a closed loop oil catch tank. But since I have only owned this car for just over a week I don't know how the original Pcv system was setup to understand if the catch tank is setup correctly.
When I picked up the car it wasn't making this noise.
I'm not sure if its related but I'm also seeing inconsistent boost.
When I punch it in 2nd it can see up to 21psi, and sometimes in 3rd I see 25psi (overboost obviously). But other times in 3rd or 4th it won't reach past 16-18psi.
Both issues are annoying me at the moment
I searched through the forum for pcv and catch can but nothing is helping my cause.
