is this a modified AAN intake?
  • momento1
    • Mar 2011
    • 358
    • Country: Australia
    by the looks of it this seller has modded an aan intake to resemble (somewhat) a Wagner intake.
    and he is selling it as a kit with the intercooler and modified throttle cable from what i gather...
    anyone see a problem with this? or would it be better just to go with a wagner intake and be done with it?
    http://www.ebay.com.au/itm/370762079...#ht_884wt_1100
    Current:
    1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
    Past:
    2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
    2001 Audi S3 Silver - 169kw+ atw
  • Acidburn
    • 13459
    looks to be a modded aan like you say.
    Some have good results, depends how its been welded up as i've heard of one done like that by azman that ended up splitting apart and having to be braced.
    • SteveH
      • 4460
      Looks ok, heavy ally plate looks to have been used.
      91 Modded 3B
      14 A6 Avant Black Edition
      • Sleeper_Avant
        • 2372
        looks like he has got rid of the external mounts and holes to access the bolts keeping it onto the head (WHY?!?!?! you life will be a misery!!!)
        one of my AAN manifolds:
        1993 URS4 Avant Emerald Green 350+bhp
        1991 Ford Sierra Sapphire 4x4 in Magenta
        BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
        • momento1
          • Mar 2011
          • 358
          what are your thoughts on the fact that the inlet now starts on the tapered side of the manifold? instead of the taper being at the furthest point.
          Any experienced people in the know about manifold flows which could chime in?
          i wouldnt think so but there isnt any chance that the first cylinder could be starved... or vise vera the furtherst cylinder starved?
          Current:
          Past:
          • Sleeper_Avant
            • 2372
            you wont notice any difference in power or torque if thats what you mean, but it will be a ******* to fit it!
            • momento1
              • Mar 2011
              • 358
              ok...
              enlighten me a little if you could (cause im still feeling my way around an S2) what would you consider being the headache in fitting? apart from the age-old adage of anything which is modified needs tweaking to fit
              Current:
              Past:
              • URQguy
                • Sep 2008
                • 245
                They flow just about the same with the throttle moved. The bolts are not hard to remove if you purchase a ball nose 6mm allen wrench, or simply convert the fasteners over to a 13mm hex head.
                I didn't realize others were modifying these. We sell a ton of them.
                On a side note, is that AAN in the b5 engine bay in teh factory location on the transmission mounts? It looks way far back!
                Hank
                1981 URQuattro with the TIAL GT35r.
                2007 Infinity g35
                • A1QSHIP
                  • Aug 2004
                  • 975
                  [QUOTE=Sleeper_Avant;707384]looks like he has got rid of the external mounts and holes to access the bolts keeping it onto the head (WHY?!?!?! you life will be a misery!!!)
                  Helps to clean up the airflow inside the intake manifold. I have seen this done on an AAN engine fitted into an Ur Quattro with the throttle port in the stock location.
                  Chris
                  "Nulla tenaci invia est via"
                  • Sleeper_Avant
                    • 2372
                    i understand why he removed the tunnels, although i have fitted/removed AAN manifolds without using the access tunnels so i know how dificult it can be
                    • Sleeper_Avant
                      • 2372
                      they do not fit a B5 basicaly!
                      this is now rwd
                      i do have a build thread in the projects section
                      • URQguy
                        • Sep 2008
                        • 245
                        get a stuby 6mm ball nose allen with a 1/4" extension. It is easy as cake!
                        Got a link? I want to put a new 5 cylinder in a b5 s4 behind an 01e. That motor is 3" shorter, so I think it is more than possible.
                        Hank
                        2007 Infinity g35
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          AAN IM's have been modified for years now, although I think mine looked much better than the one in the Ebay add: http://www.s2forum.com/forum/showthr...t=modified+AAN
                          Not made it myself but it looked pretty good, I believe I posted extra pics in a topic about short intake routes.
