Please post a pic if you have of a air filter thru the inner wing. Not thinking about the MTM version inside inner wing, but so the air filter is beeing placed in front the wheel and behind the fender.
Another option is to cut a hole in the inner wing and vent air through it from the bumper using 3" or 4" pipe. This is what SteveH has done and I will be following suit, now that my oil cooler is in the aux. radiator position
Might help if you post up some pictures of your setup
I have not started doing it yet. Wanted to see some inspirational images here first
Please post pics of this setup SteveH has.
This idea is used by A4 B6 that has a hole in the airbox and a pipe thru the inner wing .THe end of that pipe is very close to the line between door and wing. So the air goes in the airbox from the wing and also from the front of the car.
Using a 90 degree silicon hose and 90 degree alloy pipe, you can place a cone filter right up behind the headlight. If you make a turbo heat shield and a heat shield for the cone, it should work pretty well.
