What's best turbo back exhaust for s2 aby they seem expensive don't want it loud any suggestions thanks
Exhaust choice
Tags: None
I have a Miltek and it is brilliant. Sounds great when you give it the wahwah pedal but not offensive on tickover or during normal driving. I was reading somewhere that availability might be an issue now but if you could get a second hand one, onto a winner. -
Milltek or custom.
Personally, I'd be looking to have the DP modified to fit a single 200 CPI sports cat and then run a 2.75" or 3" system off that, thus ditching the awkwardly placed OE cats and Y pipes. Any custom exhaust place worth their salt should do that for about £800-1000 with the noise at the level you want. Dropping the diameter a little to go over the rear axle adds clearance and stops nasty resonance that is why most complain about the 3" systems.Cheers'en, AndyC
just having one of these fitted mated to my 3" dp using 3" pipe to it
ABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
Linky no workyjust having one of these fitted mated to my 3" dp using 3" pipe to it
http://www.motorsportworld.co.uk/fra...AGE=/start.asp
Is it finished yet?sigpic
1976 RD250E / 350LC cafe racerComment
The stuffing must been knocked out of mine as it was as loud as hell and droned on the motorway something shockingComment
