bov valve question
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    bov valve question
    Just wondering if this would work, im running a reverse manifold my throttle body pipe runs down to the intercooler off that pipe runs the idle stablizer , what i want to do is also connect my bov valve to the bottom of the main pipe(running from t/b to cooler)
    would this work . Would it steal the air from the idle stablizer cheers
  • nip
    • Apr 2006
    • 1786
    Anyone?
    • Rusty
      • 18953
      Are you running a MAF and is it on the high or low pressure side? Are you looking to run a vent to atmosphere or recirculating type?
      • nip
        • Apr 2006
        • 1786
        Hi Andy, the maf is on the normal side, I wanted to clear the clutter around the turbo area, I like the idea of the bov so it doesnt plumb back into system to clear the clutter , would a twin piston dump valve act as a recirculation valve?
        • prj
          • Mar 2010
          • 6308
          No. You have to re-circ everything post-maf if you want to use a MAF.
          • nip
            • Apr 2006
            • 1786
            Sorted now cheers
