My orginal exhaust need replacement, and i also want to prepare it for future upgrades. What is the best route to go, i need to keep clearance as good as possible, and for exhaust to flow around 500hp. 2x2.5" or stock exhaust like here ? http://homepage.internet.lu/customau...US.htm#EXHAUST
Or go to 3" all the way ?
Need to be quiet, as this is my DD.
Fit a 3" DP with sports cat - that's fine for your requirements. As to what you put after the cat, for 500bhp, you'll want 3", for more modest power, you'll be fine with 2.75".
The same area doesn't equal the same flow, due to different surface area of the pipe per unit length. 2x 2.5" would be a good option but not really necessary when 1x3" works.
The clearance on single 3'' system is better than stock least on the front side.I used to touch the humps before with stock downpipe but now no problems.
