What is the difference between S2 & RS2 Maf if any please?
S2/RS2 Maf
Tags: None
The staff here at STFA (Search the Forum Archives)
is pleased
to provide quattro corner, independent Audi parts supplier of the year, with an answer:
Electrically they are very similar if not the same. Physically they look different because of the grills involved (RR UrQ, S2, UrS4/S6 and 200 20VT on the left, RS2 on the right).
More detailed info: http://forums.quattroworld.com/s4s6/msgs/20442.phtml
So i take it they are interchangeable without any real noticeable effectsComment
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
When I "RS2'd" my 93 UrS4 in 2004, the "recipe" included the RS2 MAF because, well, that is what the RS2 ran so that's what you need. As time evolved and more info came in, it was determined (as shown in my MAF info post) that the electronics of the normal S2/AAN MAF and the RS2 MAF are the same (ish) and I could maybe have saved the $500 I paid for the new in a box RS2 MAF.
All that said, there are various discussions about the restrictions in the air flow for the S2/AAN MAF vs the unrestricted RS2 MAF. The issue is related to the need to have a screen to straighten out the airflow ahead of the MAF hot-wire and not having that screen restrict the airflow at higher engine speeds. Presumably the Porsche engineers who were looking at the ABY in the 93 S2 avant RS2 test mules thought through this a bit and decided on using the Bosch MAF that they were using in the 968 as the solution.
Today, there is an aluminum honey comb material that is said to be very good at straightening the flow while NOT restricting the flow. This could perhaps be installed in an S2/AAN MAF to duplicate the flow, etc. of the RS2 MAF.
Nice idea. That ally honeycomb is pretty cheap and used in all kinds of composite panels. I think larger cells would be better, but in reality I suspect the performance loss / gain is probably pretty intangible as these MAFs are well out of range before they become restrictive to flow
Imola B6 S4 AvantComment
Rs2 MAF is avaiable. S1 MAF tooComment
Maybe you could get Dmitri(prj) to do a MAF conversion? http://www.s2forum.com/forum/showthread.php?t=49825
BMW 740iA e38 - ProjectComment
