and another, should be able to see the y pipe running off the cats:
What system?
Originally posted by s2driveruk
Will post some pics once its stopped p**sing rain outside - just removed me battery and got totally soaked - its fun aint it
David
Cheers for those pics will show them to my mate who can build something similar.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Fairplay m8, thanks David, they will be more than useful.
Good luck with the home grown
Glad its not me praying to the porcelain godsigpic
Audi UR Quattro
Tom,
This any use to you as you were looking at rear boxes.....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=10372
Davidsigpic
1992 3b S2 Coupe
I really like that Miltek. Anyone have a link so I can see about ordering one?
Folks here in the U.S. are telling me I need a 3" exhaust for the 300hp I want to run.
What size is the Miltek?
Do you use stock cats with the Miltek and still get good results?
When removing the cats, do you still run 2 into 1 pipes?
Sorry for all the questions. S2 newbie here...Dave K.
USA
1991 e//S2 (home built S2 - the only way to get one in USA!)
2001 S4
Cheers,
mihnea'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop Directions
Mihnea,
So I can run 2.5" from the turbo to the back in a single pipe if I don't run cats?
If I run cats, I sould split into two? Maybe I could run 3" from the turbo to the 3" cat then reduce to 2.5" from there...Dave K.
USA
2001 S4
No good that way, Dave.
You'll make exhaust gasses expand and slow down after the turbo in the 3" pipe and then recompress and accelerate after the cat. This will increase back pressure.
If you run a k24 turbine keep the original downpipe till before it splits, then use a racing 100/150 cells per square inch cat converter and the 2.5" pipe all the way to the muffler.
For bigger turbos 3" turbo back will reduce lag and allow better flow on high loads and rpms (3" pipe will already work great with an RS2 turbo).
Marco
Mihnea,
