Hi
Had som issues this summer with my new exhaust, and when rebuilding my chassis of the car I found this inside the flex tube, looks like it has collapsed, it´s supposed to be 3" and the outer shape is intact but the inside
the hole in the middle is like 2cm where it suppose to be 7,6cm.
Have had problem with cracked DP flange, exhaust manifold that unscrews itself, exhaust leak around the WG and also a stumble idle problem with stupid emission result, maybe it´s because of all the back pressure I don´t know. But this is not how it should look like. The idle problem I isolated to some burned exhaust valve but this doesn't help if it looks like that I guess...
The flextube is behind my 3" catalyst race converter and then it goes a Y pipe to 2x2,25" exhaust piping.
The inside looks collapsed but not the outside
View from the rear (Y section)
Any ideas?
the hole in the middle is like 2cm where it suppose to be 7,6cm.Have had problem with cracked DP flange, exhaust manifold that unscrews itself, exhaust leak around the WG and also a stumble idle problem with stupid emission result, maybe it´s because of all the back pressure I don´t know. But this is not how it should look like. The idle problem I isolated to some burned exhaust valve but this doesn't help if it looks like that I guess...
Any ideas?
