Can someone show me how the ABY intercooler should be mounted to the crossmember?
I went to change my 3B one at the weekend, but I think the ABY crossmember that I bought has had a Wagner intercooler fitted previously and I'm missing a bracket/mount at the driver side of things.
My guess is the driver's side mount with the two bolts was cut out in order to fit the wagner bracket + IC which is further out to the right? In which case the cross member is fubbared and can only be used with a wagner intercooler unless can make a bracket of your own to re-fit the ABY intercooler
