Which exhaust rubbers
  • Rikki Kitto
    • Feb 2010
    • 6276
    Having problems with my exhaust banging on the tunnel, think it might have the wrong rubbers on it holding it too high. Any idea what ones I should have, part numbers etc, its coupe
  • Bowie69
    • Nov 2013
    • 2681
    These ones on a Coupe: http://www.ebay.co.uk/itm/Heavy-Duty...item565e26c573
    Non-chain hangers are a waste of time.
    It's also possible the joint is not done up straight, or you have the cat at a funny angle, meaning it is too close to the tunnel.
    • Christophski
      • 3632
      I have used poly hangers mate and seems to have worked a treat with a zip tie or two round each hanger... Holds the exhaust in place perfectly. (just doesnt look the best when peering underneath but if it helps then im all for it)
      • Rikki Kitto
        • Feb 2010
        • 6276
        Put some cable ties on to see what happens but need to restrict upward movement which this doesn't do
        • Christophski
          • 3632
          Try the poly hangers then as they are stiffer than oem rubber so will help reduce amount of movement even in the upwards direction.
          • Rikki Kitto
            • Feb 2010
            • 6276
            Where you get them from?
            • Bowie69
              • Nov 2013
              • 2681
              The chain reinforced ones are VERY stiff, difficult to get on and give excellent control out of the box, including upward movement.
              • Rikki Kitto
                • Feb 2010
                • 6276
                thanks guys
                • Christophski
                  • 3632
                  Umm the poly ones I got are generic rubbish from halfrauds and I had to trim one to fit but its done a good job but if you can get the metal ones then maybe you wont need the zip ties??? I may try them some point if I can find some... Still, the poly ones work well if you get hold of them easier.
                  • Bowie69
                    • Nov 2013
                    • 2681
                    The metal ones certainly don't need zip ties, and buying from Ebay is pretty easy
                    • gripper
                      • Jun 2008
                      • 1156
                      Had these on mine as I got fed up with replacing the OE ones every 6 months !
                      Very hard to fit (two exhaust centres refused to fit them)
                      In the end Protyre by me fitted them but they had to bend the brackets down a touch then bend them back when fitted !
                      Zero movement on my exhaust when fitted
                      Got mine from John at Cander enterprises for around £20 the pair.
                      For what this cost me so far I could have bought an S2
                      • Bowie69
                        • Nov 2013
                        • 2681
                        Yep, I think the workshop manual says you will need to bend them out, fit, then bend back.
                        • Bowie69
                          • Nov 2013
                          • 2681
                          Oh, and there is 3 on a coupe, 2 on the rear box, one on the middle box.
                          • Monkeymagic
                            • Mar 2012
                            • 3419
                            The chain re inforced are excellent. The polys are tosh. They just melt.
                            I went through loads on my old mk2 golf on a miltek. Fitted the chain re inforced job done...
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Looks it's the chain jobbies then thanks for the input guys
