Any advice on this? No cats, new exhaust manifold as well, exhaust is definitely not blowing. Don't have any figures as these were not provided..
It is running a bit rich though as I am running a higher octane I presume than what is required. Would too high an octane cause an emissions failure? Any advice appreciated!
I guess it depends on what the Malta equivalent of an MOT requires, in the UK any car made after 1992/3 needs to have a cat fitted to pass unless you have a 'friendly' garage.
As far as I'm aware there's no requirement to take you car back to a place that's fail it, all that matters is that is passes somewhere.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
Was the RS2 changes to your ecu done with s2 maf or rs2 maf in mind?
The MAF's are identical regardless.
I don't know what the laws are like in Malta. But in most European countries there is no way in hell you are legally going to pass MOT without a catalytic converter on an ABY engined S2.
1. The correct way:
Install a 3" 100 cell cat into your exhaust.
2. The fast way:
Bribe the MOT guy *
3. The ninja way:
a) Pour E85 into the tank.
b) Get a spare 4 bar FPR and whack it a couple times with a hammer on the top to make it a 5 bar FPR and install it for the MOT.
c) Pass with flying colours with the MOT guy thinking his machine is broken.
Will have a go at a different MOT garage, I do think I know a guy that could help me out.
Not sure why but the first time I had MOT 2 years ago at the same garage it passed using the same exhaust system but then again the guy testing was different and this guy seemed kind of dodgy did not like the look of the guy at all maybe was having a bad day
If it passed before and did not this time there could also be something wrong. You need the readouts from the machine. When you go to the other MOT place then please ask for them. They do tell a lot.
Did I do your software or was it someone else? I am sorry, there's just too many cars to remember by now.
Will definitely get the readings next time, Will had the software done for me.
