twin throttle body 2.3 20v
  • WabTheKing
    • May 2004
    • 2567
    working on an idea at the mo with a friend, on a n/a 2.3 20v we have added another throttle body on to the manifold at the oppersite end to the existing one, so long as the air feeding both of these goes through the one air flow meter should this work?
  • S2 Ant
    • 3682
    I think it would need to have exactly the same flow thru both inlets, otherwise if there is a greater flow or pressure from one than the other then its likely to flow in the high pressure one and out the other due to the pressure difference i think.
    Ant
    2011 Kawasaki Z1000
    • Graham
      • 1622
      I would have thought that it would work, once the air is in their, there is only one place it can go, through the engine, but the throttles would have to be identical in movement for tickover purposes, or one would have to seal completely to allow the ISV to work.
      • mcandmar
        • Apr 2004
        • 5118
        It might confuse the ECU as it monitors the throttle body position, the engine would get more air than the ECU would think possible at any given throttle opening. In theory twice as much if there are two identical throttle bodies.
        What I always found curious is the sensor for the throttle position reads WOT when the small throttle body is fully open. But this is only half of the throttle pedal travel, the other half opens the large throttle body
        Do you have an S2 throttle body spare? Curious to see if we could change the dual butterfly to a single choke throttle body. I wouldn’t be surprised if it did wonders for low down throttle response.
        It’s an unusual idea all the same, if you get it going please keep us posted.
        Mark.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • jogi730
          • 2335
          Moving on from this idea, maybe better off trying one TB per cylinder? That could well work as each cylinder being fed same amount as opposed to air coming in from just 2 points?
          Any thoughts?
          Chris
          PS> What would this do to fuel consumption?
          Audi 90 quattro (Typ 85)
          20v turbo conversion
          • gavs20v
            • Sep 2004
            • 3057
            Theres a guy on audifans (aspro i think) doing a throttle body conversion on his 2.0 16v coupe, very interesting stuff. Hes using Motorbike throttle bodies.
            Nice one
            Gav
            S2 Cabriolet.........
            • S2 Ant
              • 3682
              That idea would prob work well and is how BMW's work, would probably work well for distribution of air flow to each cylinder too
              Ant
              2011 Kawasaki Z1000
              • S2 Ant
                • 3682
                Actually looking at what i wrote earlier that would be wrong as obviously the lowest pressure would be in the engine itself so air would be drawn in from both inlets.
                Ant
                2011 Kawasaki Z1000
                • ottawa coupe
                  • 862
                  ITBs are pretty neat but there's a coupla obstacles i think (from me just museing at my computer instead of working!) that need to be addressed. the first is, how do you meter the air? you could have a simlar layout as factory and use the original MAF but then, due to the length and routing of the intake, you'd probably negate any benifit of the ITB. the other thing is that you'd, at the very least, want to re-map to get the proper mixture, some form of standalone would probably be better.
                  1993 UrS4...aka the rocket powered living room
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    Why?
                    • WabTheKing
                      • May 2004
                      • 2567
                      Originally posted by Audi_CQ
                      Why?
                      ive pleaded with him to get an s2 but its like talking to a brick wall, i am just assisting him in his development,
                      • Audi_CQ
                        • 940
                        • Country: Norway
                        My point was that's of no use to mount another throttle body. The original one is large enough so there would be no powergain. An easy way to check if you got any restrictions from airfilter to manifold is to use a vacuum gage. Check pressure in manifold on full throttle and compare with pressure in free air. If no difference there's little to be gained with other filter and larger (second) TB.
                        Separate throttle bodies would help some, but probably not justifing the cost.
                        Cheers,
                        Roger
                        • WabTheKing
                          • May 2004
                          • 2567
                          the car owes the guy nothing and nothing has been bought to do this as i had all the parts to do this as i had 3 7a engines so just playing with ideas really, we have another intake manifold if it doesnt work so nothing would be lost, at the end of the day he who never tried never succeeded! im only 21 therfore have alot to learn and theres no better way of learning than from experiance (so everyone keeps druming in to me)
                          • WabTheKing
                            • May 2004
                            • 2567
                            right, we have come to start the car, (in standard set up) but no spark at the coil, fuses under the red motor cap all ok,feed going to the coil pack, dizzy isnt alined would this make a differance to the spark from the coil pack?
                            regards
                            will
                            • porkkis
                              • 1994
                              Dunno 7A but 3B must have the dizzy aligned as the hall gap is used as a gate for the flywheel BTDC sensor.
