Great read on separate wastegate pipes and turbocharged engines exhaust theory.
  • Mihnea
    • 1288
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Cheers Mihnea. So a large diameter exhaust won't hurt the stock setup, but will be a big advantage if I ever want big power.
    Hmmm..... How much ground clearance have I got? I'm sure I saw some 6" stainless kicking about somewhere!
    SS
    • Mihnea
      • 1288
      6", bring it on 4WD
      And I thought some people had gone nuts when we started talking about 3.5" or possibly 4"
      Mihnea
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Uh. On second thoughts... That might be a bit tricky. **** it! A stack going straight up through the bonnet might be the answer!
        SS
        • robo
          • Aug 2004
          • 2086
          Ok I will not be joining wg pipe with dp then, can any one suggest small silencer for wg pipe maybe motorbike one???
          _______
          Rob
          sigpic_________
          Rob
          • s2_southwest
            • Oct 2004
            • 823
            From what i understand (which is not a lot) of the seperate WG pipe, the idea is to have it as seperate as possible, i.e. does not join to the main exhaust or DP...
            And people have been complaining about the noise from seperate pipe, why cant the pipe join in just before the rear silencer, rather than having a sperate silencer for the WG pipe. This way it does not join onto the DP, and should reduce some of the noise...or am i missing the point completely lol
            Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
            • martinjs
              • 3205
              Think that sort of defeats the object a bit lol
              The idea is to keep it completely seperate so it doesnt interfere with the flow of gases in the main exhaust.
              Im sure a small silencer will be fine, but im gonna try one without first, maybe get it sorted at the garage meet if i get all the required bits.
              • Erikb
                • Jul 2004
                • 648
                Very interesting article, thanks for sharing Mihnea.
                Does someone already know if it will pass the MOT test?, I think it will need a catalytic converter and a silencer to pass.
                Getting everything sorted out for my 5++ hp project
                • robo
                  • Aug 2004
                  • 2086
                  I think if you have just pipe coming out, then you can say is dump valve?? :mischeif:
                  It would be bit tricky to explain when with silencer.
                  ______
                  Rob
                  sigpic_________
                  Rob
                  • audiman
                    • 4827
                    AS long as it doesnt blow, which it wont when MOT testing then it doesnt fail. If an MOT tester tries to fail it, then appeal.
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      I'm not sure what an MOT tester thinks he's doing, if he gets your WG pipe to make a noise. Have they got a rolling road in the testing bay?
                      SS
                      • NoNonsense
                        Forum Sponsor
                        • Apr 2004
                        • 673
                        RPM and boost wouldn't be high enough unless the MOT tester is revving your car like you would
                        Joe "NoNonsense"
                        axis motorsport
                        joe@axismotorsport.com
                        • audiman
                          • 4827
                          when you MOT an S2 you have to drive it to test the brakes as its perm. 4wd you shouldnt put it in the brake roller tester. But we arent allowed to drive fast 30mph ish. But then some people will thrash customers car when the come into the garage. Not me, cos i know that if someone did that to my car i would be very very angry.
                          Audi UR Quattro
                            Hey some nice new thoughts in there for me. The logic seems sound with free-er flowing exhausts improving VE for our turbo engines. Reality seems to agree with that also when power and torque gains can be seen with a bigger exhaust using the same ECU software. The engine flows more air (higher VE) and therefor produces more torque at the same boost levels...
                            Bet this guy can read turbine maps
                            Paul
                            • maRS2
                              • Oct 2003
                              • 366
                              • Home: France Current: Thailand
                              I see that you guy 's start to look at the scooby forums!!! lol
                              This one was one year ago on nasioc forum
                              RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
