wedge? on throttle body butterfly
  • momento1
    • Mar 2011
    • 358
    • Country: Australia
    anyone know the reason for the wedge on the butterfly as per the pic. At WOT is looks like it would restirct some airflow...
    It kind of looks to me like they were aiming to directing airflow however if im going the reverse intake path i dont see the point of it...
    any input would be great as im thinking of removing it and pluging the holes.
    Current:
    1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
    Past:
    2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
    2001 Audi S3 Silver - 169kw+ atw
  • Mcstiff
    • Oct 2004
    • 504
    1995 1PissedOff90sigpic1991 USDM CQ 7aT
    • quattrostyle
      • Oct 2006
      • 6229
      He is talking about the 20VT throttle body. I deleted it on one of the S2's I owned. Can't tell if it made a difference as I did a lot at once then.
      • momento1
        • Mar 2011
        • 358
        thanks quattrostyle
        so no ill effects then after you removed it??
        sounds fine to me, i dont see the need for it really
        Current:
        Past:
        • quattrostyle
          • Oct 2006
          • 6229
          No ill effects AFAIK, I did get the ECU throwing a code every now and then after multiple times WOT though. I can't remember exactly but it was a 5 digit number and starting with a 5 as well I believe. That could have been caused by multiple factors I guess.
            It's there for part throttle control to make it smoother and more progressive, if you remove it or make the throttle body wider it becomes very twitchy to pedal response
              There's been a few threads on this but I remember this one on audifans http://www.audifans.net/ftopicp-65432-.html
              He didn't like the results on removing it!
              034 offer it as a service IIRC
              • momento1
                • Mar 2011
                • 358
                so its probably fair to say that it smooths out part throttle.... which probably makes sense thinking about it... but at WOT it looks like it would dampen air flow a bit....
                ok i guess it stays in place for now then...
                GT3071 turbo upgrade is almost finished... !!!!
                Current:
                Past:
                  There is no way it's going to restrict a setup with a 3071 turbo
                  • momento1
                    • Mar 2011
                    • 358
                    every bit counts.....
                    Current:
                    Past:
                    • twenty valve
                      • Oct 2010
                      • 630
                      I didn't think twice before taking mine off, again I did a lot of mods at the time so can't comment with and without it. I can say however that with Dmitri's mapping it runs like a swiss watch. You'll need to plug the 2 holes it leaves behind though, I countersunk them both sides and used some solid brass rivets. Whatever you do, make sure it can't come out!
                      • 20Vcqdriver
                        • 829
                        I didn't remove mine altogether but i did reduce its size, There is a pic of it in the Audi Driver magazine , will try and dig pic out at some point this week.... Actually prefer it as I get better part throttle acceleration but still good control when cruising...
                        1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                        2004 A4 2.5TDi convertible, re-mapped to 180bhp
                        2011 A5 sportback 3TDi-Backbox delete, remap
                        • momento1
                          • Mar 2011
                          • 358
                          if you could dig up some pics that would be great...
                          i would no doubt get used to the throttle responsiveness in a short period of time anyways, and its not a daily driver... so maybe i could bare with having it gone, or perhaps at least reduce the size of it as 20Vcqdriver has done
                          Current:
                          Past:
                          • A1quattro
                            • Jul 2006
                            • 789
                            we machined out the throttle body by 2mm and made a 2mm bigger flat butterfly , i got the idear from 034 site , fitted to rally car so its not on part throttle much if at all
                            • Kieron20V
                              • Mar 2008
                              • 1505
                              Don't you run a restrictor anyway Ray?
                              Sent from my HTC One_M8 using Tapatalk
                              1994 URS4 Avant RS2+
