Exhaust pipe for audi coupe 2.3
  • audicoupe2.3
    • Nov 2012
    • 82
    • Country: Spain
    Hi all, the exhaust pipe of my car for a few already, is the original car and with his 24 years on the backs did not think much more endurance. Already misses some point. What is worse is the joint in the middle. I have several ideas in mind. And before I do anything I wanted to consult you as tailpipes'm not since.
    My car is a 90 coupe 2.3 year, from the first 2.3, and puts it in the documentation is not catalyzed and made ​​me so pass it on itv, uncatalyzed. What I thought that would be bad because in the documentation, but from what I read online and mine may not Catalyzed truth and this is just a silent since the first lambda probe 2.3 traian but quiet as 2.2 instead of catalyst.
    Since I'll have to repair the leak, whatever catalyst or I will not buy or make a suppressor.
    and here come the questions. Do they sell suppressors made ​​for 2.3? e not found online. It would be difficult to do, I think that no. I dont know ..
    Like the rest of the exhaust pipe is too bad I would like to know where to buy cheap price escapes. And if failing me new van price, know that models are compatible to search scrap yards etc. .. If you like the 2.2. that the audi 90 .. etc ...
    * diameter is 55 mm.
    Thank you.
  • audicoupe2.3
    • Nov 2012
    • 82
    • Country: Spain
    This is the joint that connects the catalyst to the next section, is what this worse. I looked and I sold this loose joint, but below danger that this rotten too ...
    • audicoupe2.3
      • Nov 2012
      • 82
      • Country: Spain
      As you can see the screws, to call in some way, almost material are left with ...
      The last stretch is bad but not so much ...
      • audicoupe2.3
        • Nov 2012
        • 82
        • Country: Spain
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          Audi 90 B3 2.3 10V FWD exhaust must be direct fit.
          Also new cheap aftermarket replacements of rear and middle parts exist, but they are poor quality compared to OEM. Downpipe and catalytic converter are possible only in OEM version.
          All new hand-made exhaust may be worthy.
          • audicoupe2.3
            • Nov 2012
            • 82
            • Country: Spain
            Thank you
            Does anyone know where I can buy a suppressor catalyst for my car?
            • audicoupe2.3
              • Nov 2012
              • 82
              • Country: Spain
              As I can not find any suppressor, and I do not know if I can. Anyone know if the silencer of a coupe or 90. 2.2 KV. It supports 2.3 NG. ? And if the 2.2 has the silent hole for the lambda probe?.
              Thank you.
              • audicoupe2.3
                • Nov 2012
                • 82
                • Country: Spain
                I found this forum. It is a flexible exhaust catalyst instead, shall be purchased or made ​​by hand? It seems to be well done ...
                • audicoupe2.3
                  • Nov 2012
                  • 82
                  • Country: Spain
                  bought
                  repaired:
