My cone filter fitment
  • s2_southwest
    • Oct 2004
    • 823
    well, here it is, nothing special and nothing new from what other people have done, bit it looks and sounds brilliant i think, aswell as maybe a slight increase of performance once i get round to having the car mapped.
    2 90 80mm bends used, joined with ally pipe and a K&N universal 80mm filter.
    Just need to weld on a bracket to secure the filter, make a heat shield and put in some sort of cold air feed pipe. Will post more pics when all is complete.
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • S2 Ant
    • 3682
    nice, just need a heatshield now too
    Ant
    2011 Kawasaki Z1000
    • s2_southwest
      • Oct 2004
      • 823
      Yep! one is on the way
      • jeroen
        • Aug 2004
        • 100
        What is the noticable difference in sound??turbo whistling and blow off ??
        • coupegt
          • Jan 2005
          • 218
          • Country: Denmark
          nice work, def. on my "to do list"
          • s2_southwest
            • Oct 2004
            • 823
            Yes, you can hear the turbo spool up and whistle and the same sound you get from having a non-recirc dump valve. Thats the next thing to change on my to do list.
            • JasonS
              • 112
              where did you get the pipe?
              1996 A6 TDI Quattro Avant, Xenon HIDs, A4 Autodipping rearview.
              Previous: UrS6 with RS2 bits.. <sigh>
              • rotoryboy
                • May 2004
                • 3281
                I would think it's from here
                Mark
                Race Clio RS197
                S2 Coupe ABY (Green) - RIP
                S2 Coupe ABY (Blue) - Sold
                • jeroen
                  • Aug 2004
                  • 100
                  getting an non recirc dump valve wouldnt be the best idea IMHO since the amount of air that the maf has calculated wich would be in de inlet path is not correct any more! and could also take turbo slightly longer to get the air path full again
                  • s2_southwest
                    • Oct 2004
                    • 823
                    yep thats right, ordered it over the phone
                    • s2_southwest
                      • Oct 2004
                      • 823
                      Yes, was just saying that the sound you get from fitting a filter, is similar to the sound of having a non recirc DV, for those who havnt got a filter fitted yet.
                      I will be getting a recirc DV, forge probably
                      • dan_b
                        • Sep 2003
                        • 3670
                        Looks nice!
                        • JasonS
                          • 112
                          I had spotted that its SFS hose, I wondered where the aluminium pipe came from..
                          • auditude
                            • 407
                            While searching around the net for parts to do something like this to my car, I found this page with parts for a Ford. Some of the stuff is pretty interesting. There are configurable maf sensors, maf to speed density conversions, and various brackets, hoses, and adapters. I haven't determined if any of it is usable for a 3B, but here's the link:
                            Kenneth
                            1990 Coupe quattro
                            1991 200q20v x 2
                            1985 4ksq 20vt project
                            1986 Coupe GT 10vt project
                            2006 Honda Ridgeline
                            1998 Honda VFR800FI
                            • s2_southwest
                              • Oct 2004
                              • 823
                              Jason, the pipe was from a metal supplier here in plymouth, took me 4 trips to different companies just to find it, nightmare. Its 3in, couple mm wall thickness, ideal size for what i was usuing.
                              Good find there auditude!
