advice on cats / performance RS2
  • Tzummie
    • Mar 2011
    • 116
    although partially mentioned in different threads, am looking for experience info on what to do with cats on an RS2: What are the effects of leaving them out? (performance-wise?, MOT-wise?, sound wise?) and what alternatives are there (metal cat? brand? performance reduction?).
    Current set-up is standard downpipe + cats, cat-back BN-pipes 2x 60mm all the way, with two boxes (middle/end). Chip tuned.
    thanks in advance!
    T.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    If you have that system then sound wise I'd say you can bare quite a bit of noise. Removing them would get you a bit more power I suppose. If you want them in I have the BN pipes 200ci cats and they are metal and pretty good
    • Tzummie
      • Mar 2011
      • 116
      hahaha.. "bare quite a bit of noise"..
      No, I'm not happy with the sound of BN-pipes AT ALL, but will be dealing with the 2k drone by installing resonance (Helmholtz) pipes.
      Am wondering what cat-less would bring in terms of power (and emission issues), or what the difference would be with 100-ceel / 200-cell metal cats.
      Any noticeable improvement with your 200-cell cats, over the originals?
      • 220bhp
        • 2578
        • Home: United Kingdom
        Speak to prj on hear, and he will tell you, in no uncertain terms what will happen If you decat an RS2 without a remap.
        • Tzummie
          • Mar 2011
          • 116
          hmmm. I will, but sounds like a
          • JariP
            • 193
            Aren't the RS2 original cats 200cpi metal one's already?
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              Original ones are 400 cell if I remember correctly. I was told that using 100 cell you could still run into MOT problems. I used briefly BN pipes. I could only stand them for 2000kms. I then removed them permanently and passed them on to Billman
              • JariP
                • 193
                Well I have a pair of original RS2 cats laying around and I once counted the cells and came up with the 200 cpi numbers.
                • Tzummie
                  • Mar 2011
                  • 116
                  would the 100-cell metal cats offer a significant improvement in performance over the (prob. clogged) OEM ones?
                  thnx.
