I have an original RS2 middle and cold section bolted to a standard K26 #6 it’s a hybrid that I would like to get back to completely RS2 original specification.
I also have an original RS2 turbine shaft and wheel and the dimensions are not the same as the K26 turbine wheel. So I can confidently say the hot side is the odd piece on the turbo.
I read the comments by Scott Justasson about the RS2 "Comp" turbo and the way I read it he talks about the cold side (compressor) being larger. I am quite sure I know what I have and it’s just a standard RS2 with a modified hot side because the original owner could not get an original RS2 turbine housing to replace the one that was damaged.
UrS4boy I may be going at my problem the wrong and confusing and concerning myself for nothing.
Below are the measurements of the turbine wheels. As you can see the K26 is larger in diameter and the wheel is wider thus I think will result in more lag. And also is of concern to the person doing the map for the car.
To reduce lag and reduce possible issues with software surging etc because of the mismatched turbocharger components I would like to fit a replacement turbine housing and fit my RS2 turbine wheel effectively retuning the turbo back to a standard RS2 turbocharger.
This is the only way I know to get the Turbo back to standard without thrown the turbo I have away and starting all over again?
Turbine wheel presently fitted to the turbo
All size in mm
A 54.5 Small diameter
B 64.3 Large diameter
C 10 The width of the flat part across the top of the wheel
F 24 Total width of wheel
G 12 Number of blades
RS2 Turbine wheel I have wrapped up in a box
All size in mm
A 52.8 Small diameter
B 58.9 Large diameter
F 20 Total width of wheel
orsum
All size in mm
All size in mm
orsum
