Wagner IC Issue
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    Wagner IC Issue
    Ok guys, I installed A Wagner Evo1 IC on my RS2 yesterday and I can“t get the original hose on inlet side on. I really tried but the hose just does not stretch enough to go on.
    Does anybody know if the replacement from Samco or GTM will work here or do I have to play with some adapters ( which BTW I do not prefer)?
    Thanks for input in advance
  • Henkjan
    • 1705
    I have the reverse inlet IC, and there I had to use an adapter to make it fit iirc
    • BosnianS2
      • Apr 2005
      • 322
      Well I made up adapter at work yesterday from 55mm down to 50 and shortened original hose to fit and on IC side i used piece of 55mm Samco extremen hose. It does not look all that great having three clamps next to each other, but it works.
      I know that this subject about direct fit was mentioned before but this is not direct fit. It would not be a problem if Wagner said at begining that inlet side is bigger than stock so one can prepare neccesary peaces.
      Anyways, problem is solved now
