Injector seal insert
My old ones fell to pieces good job the manifold was on the bench, I used the white ptfe tape that gas fitters use otherwise you will get leaks
I will second this. I changed mine 2 weeks ako and and it was definately good thing that i removed the manifold from the engine cause old ones fell apart while trying ti unscrew them
Injector Insert Re and Re DIY with sealing hints
I did this for my AAN brothers but most of it will work for a 3B, ABY or ADU.
Click HERE: http://forums.quattroworld.com/s4s6/msgs/266127.phtml
Definitely recommend intake manifold removal as the first step. Those inserts are 20 years plus old and they are brittle and will fracture when you use a 10 mm hex tool to remove them.
I tried to avoid the intake manifold removal and instead was rewarded with this:
Here are my insert sealing "tools"
