Thick walled Aluminium tube and bends
  • SteveH
    • 4460
    I'm Looking to fabricate another reversed inlet but struggling to find a UK supplier of thick walled alloy tube and bends. I don't want 3Mtrs or more of tube which rules out lots of suppliers. I'm after 1 mtr or of 4" pipe with a 4mm to 5mm wall and a 3" 90 degree bend with similar wall thickness. Anyone have any or have suggestions for a supplier?
    I plan to use the runners from a 3B inlet to create the new manifold which will allow me to retain the PAS pump in the original location. Probably not the best flowing runners, but hopefully something which will be fine for 450 to 500HP.
    Any suggestions or experience of undertaking the same process would be great
    91 Modded 3B
    14 A6 Avant Black Edition
  • AndyP
    • 6049
    £48 for a 1m length of 4" x 3/16" wall
    I'm still looking for bends, think they're going to be more tricky in that wall thickness.
    • AndyP
      • 6049
      $87 from Australia??!
      • speeding-g60
        • Aug 2008
        • 1186
        dont rule out rigid aluminum conduit.
        its aluminum, sch 40 is thicker walled material, and they have all kinds of radius bends.
        • andy10v
          • 5996
          Are you going to get hemispheres for the ends?
          ian4455 made some
          Derracudas one with taper feed
          well folks.... after my episode with the 86 zermatt car from NC with the paint issues and whatnot, and then my issue with not being able to stop for blazers in front of me, i decided to console myself with buying the car i originally wanted before going to NC.... a very clean, very nice 4kq, a...
          Sold ABY-stock
          • andy10v
            • 5996
            Tons of sch 40 in the US for reasonable money, seems harder to get over here.
            Sold ABY-stock
            • SteveH
              • 4460
              Originally posted by AndyP
              http://www.simmal.co.uk/buy-aluminiu...2-od-and-above
              Cheers Andy I've looked at this site in the past. Seem to remember there was something which put me off. Could be excessive delivery charges or something like a minimum order value.
              91 Modded 3B
              • SteveH
                • 4460
                I will have a look, thanks. It's really annoying, everything you find on the web is US based. UK suppliers are pretty restrictive on options!
                91 Modded 3B
                • SteveH
                  • 4460
                  [QUOTE=andy10v;852689]Are you going to get hemispheres for the ends?
                  ian4455 made some
                  I like to do things on the economical side, so probably flat sheet
                  91 Modded 3B
                  • speeding-g60
                    • Aug 2008
                    • 1186
                    i am in the US. i even have some of this stuff sitting on the shelves here at home.
                    i send stuff to TerryBullwon all the time, and others too.
                    if it is sourcing that is a problem, i could find it for you i am sure.
                    and i am the one who had Dereks manifold all welded up, too. he was learning with my TIG machine and had my fab guy weld that one out for him.
                    • SteveH
                      • 4460
                      Thanks for the offer You are lucky in the US that's there are plenty of businesses that cater for this type of thing. I'm finding more and more that most of my eBay searches point to US suppliers.
                      91 Modded 3B
