powerflow stainless?
  • slim
    • Oct 2004
    • 66
    had a quote today for a cat back stainless system from powerflow for £325. does anyone have any views on these pipes.it seems like a good price.
    S2. NICE MIND
  • s2_southwest
    • Oct 2004
    • 823
    from what ive seen powerflow use a low grade SS, ive seen mild steels systems looking in better condition than theirs.
    Longlife seems to be the best alternative, apart from miltek
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
    • rotoryboy
      • May 2004
      • 3281
      Apparently they use a low grade stainless. Longlife is a better option and we can get discount if we use the Leeds branch
      Mark
      Race Clio RS197
      S2 Coupe ABY (Green) - RIP
      S2 Coupe ABY (Blue) - Sold
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Longlife are good. I know a man who supplies them.
        SS
        • slim
          • Oct 2004
          • 66
          do you have a phone number for longlife,or do they have a www. cheers
          S2. NICE MIND
          • s2_southwest
            • Oct 2004
            • 823
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              Try to stick a magnet to your exhaust. That'll tell you something about the grade of stainless.
              SS
              • rotoryboy
                • May 2004
                • 3281
                @slim - PM
                Mark
                Race Clio RS197
                  Do not use powerflow, they use grade 409 steel which rusts after a month. Also all there back boxes are pre built and have they have to modify them to get them to fit on the various cars. Avoid like the plague
                  Longlife use 304 or 309 grade which is what you want.
                  • The Spanish
                    • Nov 2003
                    • 719
                    I have a Cat Back Milltek system for sale for the ABY Coupe (6 gears).
                    It has only done 2000 Km. and I recently build a custom turbo back system this is why I am selling it.
                    PM me if you are interested.
                    94' RS2 Coupe TT (Twin Torsen )
                    • slow2
                      • Apr 2004
                      • 238
                      Hi Spanish
                      Is this system 65mm or 76mm
                      Dez
                      Never did overtime until i purchased........s2
                      • The Spanish
                        • Nov 2003
                        • 719
                        The Milltek coupe system is 2,5 inches wide (ca 65mm) the avant system is 3 inches (ca 76mm) this is because the clearence issues over the rear subframe for the coupe. The avant exhaust goes under the subframe.
                        • The Spanish
                          • Nov 2003
                          • 719
                          Hey Slow.
                          You are only 2 posts away to see the For sale forum.
                          PM sent
                          • slow2
                            • Apr 2004
                            • 238
                            Thanks for info,
                            i was hoping for 3 inch, forgot it was avant only that was 3 inch
                            Dez
                            • The Spanish
                              • Nov 2003
                              • 719
                              There is no "off the self" 3 inch exhaust for the Coupe.
                              The best you can buy is 70mm at www.bn-pipes.de Cat-back systems is close to 1200€ though.
                              Anything else has to be custom made.
                              If you are planning on over 330 bhp you need a turbo back system bigger than 2,5 inches. At least 70mm
                              If you want to stick to stock car or Home fry (ca 280 bhp) the standard system is ok and the Milltek will give you some more hp but mainly better sound.
                              Think what you want in the end before you buy.
                              Cheers.
