Does the PS work with stock inlet manifold, pipework etc.?
Phenolic Spacer + Stock IM
1994 ABY Coupe - Projekt AlpinweissComment
I think it's BS to be honest. Think about the gas velocity through the manifold. Maybe with one of these you can drop the intake temp a few degrees for a few hundred yards after sitting in traffic. After a decent run I can pop the bonnet on mine and the IM is cool to touch. Also where the IAT sensor is located on the manifold, even if they had an effect I can't see it register any performance increase anyway, in fact the reverse is possible. At WOT the ECU will still be fuelling based on its map against the charge temps entering the IM. If they are in fact cooler, you will be running leaner AFR.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
Yes, it may reduce IAT sensor heat soak when in slow traffic or when hot engine has been shut and started again. But at WOT... propably no difference.
BMW 740iA e38 - ProjectComment
IAT temp can easily rise from 20C to 50-60C when the hot engine is turned off. Don't know how factory motronic is setup to handle this nicely on engine start, but it can be difficult to adjust on standalone ecu systems.
