Help !! Turbo Flange needed - Fast !
  • RS2junkie
    • Mar 2011
    • 409
    • Home: Ireland Current: Bahrain
    Hi Chaps, need some help !
    Car is in bits getting a milltek and 3" DP fitted and just realised I need a 3" flange to fit the DP to the turbo..
    Anyone know where i can get one, need it quick. Found one in the US but its 5 weeks away ??
    Any help appreciated...
    Paul
    note to self.... plan ahead next time... dooooooh !
  • SteveH
    • 4460
    Might be quicker to get one laser or water jet cut locally. Here's the pattern. I assume it's for a KKK turbo...
    91 Modded 3B
    14 A6 Avant Black Edition
    • RS2junkie
      • Mar 2011
      • 409
      Steve,
      Appreciate the info, I will check around...
      Only slight issue is I am in South Korea right now trying to sort it out, thank F for the internet !
      Will let you know how I get on..
      PAUL
      • RS2junkie
        • Mar 2011
        • 409
        Soooo... anyone able to suggest a workshop who could knock one of these out quick ?
        Assume it needs to be stainless steel, with a 3" hole for the DP, thickness ?? 15mm ?
        Thanks guys !
        Paul
