3" system fitted
  • auditude
    • 407
    Originally posted by Greg_S
    Looks very good that one. What size thread are you having put in? In mine i use labfacility thermocouples and there's have glands with 1/8BSP threads. Im gonna order some more up soon since I had to open an account with them if you want the bits let me know. From memory it works out about 15 for gland and thermocouple.
    What kind of gauge is used with those thermocouples? Are these things standardized or universal? I have been using Autometer gauges, which are available with their own thermocouple. I wonder if this would work out cheaper/better/different.
    Kenneth
    1990 Coupe quattro
    1991 200q20v x 2
    1985 4ksq 20vt project
    1986 Coupe GT 10vt project
    2006 Honda Ridgeline
    1998 Honda VFR800FI
      • 12431
      as long as your autometer takes a K type thermocouple it should be a problem. The ones I used have a mini K type plug on them and you need a female one for the gauge wiring. The thermocouple is 3mm dia so as long as you have a gland with the right size hole for the thermocouple it doesnt matter which one you use.
      • s2_southwest
        • Oct 2004
        • 823
        Thanks for the advice guys, i'll post up what ever i do just for reference and greg i'll let you know if i need any bits. at work we use k type RT (resistance thermometers) which are 4 wire, anyonw know if these would be any good? i'll find out what range they operate upto
        Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
          • 12431
          possibly. These are the ones I use.
