has any one on here tried one of these ebay 261971136009 , ive just bought one , not fitted yet .
exhaust noise diverter
Here is one example:
IF you are into that sort of hooliganism stuff
At least it was after the catalytic converter (Stromung system)
Details: http://forums.quattroworld.com/s4s6/msgs/186091.phtml
Video: https://www.youtube.com/watch?v=8VuK...ature=youtu.be
I've got one of these from Germany: http://www.ebay.de/itm/76mm-3-elektr...UAAOSw9N1VmlJc
Wired up the controller to my battery under the rear seat then the wiring to the exhaust underneath through one of the many holes! Mounted the piping before the rear subframe just opposite the battery tray, nice space there. Operates wirelesssly via remote. Very smooth and so pleased with it!
1996 S2 ABY SilverComment
Will try get a vid up asap but haven't been using the car as of late. This is the pic from the underside, I decided to route the piping under the right rear wishbone behind the wheel for added sound for the driver. Sounds mental!
https://scontent-mxp1-1.xx.fbcdn.net...61&oe=574168901996 S2 ABY SilverComment
I will say ive never had one but am a little sceptical. would be nice to hear one maybe have it linked up to rpm or boost so it opens higher up the rev range so it quiet low down in traffic but free flowing on boost.
maybe linked to boost level signal or controller output. boost a better bet so motorway cruise is quiet
doubt it would make any difference with mine though.Comment
I have exactly that. 110mm vacuüm valve controled by vems. Works very quick so when you shift down the valve opens instantly. I will post Some photos when im home.I will say ive never had one but am a little sceptical. would be nice to hear one maybe have it linked up to rpm or boost so it opens higher up the rev range so it quiet low down in traffic but free flowing on boost.
doubt it would make any difference with mine though.1360kg/600Whp Avant
0-200km/h 9secComment
I also have no cats and one box all 3.5inch. I did want the original look and no performance lose. I did use the original rear box. Im on my phone now so i have no photos and my spelling must be very bad
but i will show Some photos when im home and dont vorget 😅
1360kg/600Whp Avant
I have to agree with Andy, ever since I got in his car a year or so ago I had to have one! Worth the investment and you get a bit more refinement running the single box at the back compared to just running a straight through system
Having the pipe run through just behind the driver's ear is heaven on full chat
