Aan inlet reversed mod done but?
  • mac2226
    • Jun 2008
    • 1289
    Hi I'm having trouble fitting my power steering to a Aby engine using Aby power steering bracket,is aan bracket different or power steering different? As I've got every thing right down to power steering fowling aan inlet could some body
    AAN belt arrangement is totally different. Normally on a reverse inlet setup you need to use a shorter tensioner bracket and slightly shorter belt. I guess it will depend on how you have done your conversion - pics will help
    • mac2226
      • Jun 2008
      • 1289
      Hi Alex the aan inlet has been modified so it's a reverse style inlet but that's not the problem it's the bracket which holds the power steering does the aan bracket and power steering pump need to be used?! Or is it same as Aby bracket and power steering pump as it fouls inlet my friend said you can grind it?
      • betterwith4
        • Dec 2014
        • 568
        I saw something about grinding a small bit away so it just clears but having trouble finding it now -.-
        Sent from my SM-G925F using Tapatalk
        • martinjs
          • 3205
          Have you modded your water manifold yet?
            You can get a bit more clearance by filing the bracket down. With the Wagner, the PAS line banjo bolt then becomes the problem. Mine fits JUST using the standard 1025mm ABY belt. A lot of people use a slightly shorter 1013mm belt. I have a brand new Gates one here surplus to requirements if you need one
            • martinjs
              • 3205
              There's a bit more info in this thread I started back in the day.
              • martinws
                • Oct 2008
                • 917
                Depending on how much you like fiddling with cars, you can move the PAS pump to the other side of engine if you haven't got aircon or you can mod the bracket and fit a smaller belt as said above.
                • mac2226
                  • Jun 2008
                  • 1289
                  Thanks every one I've think I've got the idea and thanks Alex for detail pics
