Hi guys, have a bit of a problem with exhaust sitting too low. Have already checked all the rubbers and none are missing or excessively sagged. I had to already remove the brace from under the car as it was hitting it all the time.
Any suggestions?
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDI
Audi 90 / 80 / Coupe quattro / Cabriolet - Re-hanging a stock B4 exhaust... - 1st photo: The rear muffler is hanging low and also notice how the hanger (left of the muffler) looks almost completely collapsed (that flattened slot in the rubber below the muffler support arm is actually a round hole when there is no...
Mine is S4. I'll lift her up after work and see what I can do, does my head in. Seems that its only sitting lower between downpipe and middle muffler. Rest is OK. Thanks for the photos
'93 Audi UrS4 Avant
Get some of the exhaust hanger rubbers that are chain reinforced. On my avant I had tried poly ones with zip ties and it still wasn't good enough. I now have the chain reinforced ones and it's perfect!
OE 3B, AAN, ABY and ADU Exhaust Components: a consolidation of info.
Originally posted by hunker7
This is on my grey yeah. Item 6 below. Bolts on where near cats.
That Item 6 "brace" was designed and installed for a good reason. Removing it to solve an exhaust issue is a bad solution. Strongly suggest that you find the chain-reinforced rubber hangers that others have suggested to you and reinstalling that brace.
I'm aware it's there for a good reason. But when your exhaust bangs against it constantly, and don't have a quick fix that's what it takes. I'll see if I can order some today. Thanks for the info as usual
'93 Audi UrS4 Avant
