Exhaust sitting too low
  • John.
    • 2615
    Originally posted by John.
    It'll have a braided flexi part on the downpipe then........maybe this has stretched??
    Ignore this, I thought it may of had a fexi part on the vertical part of the down-pipe....but Dave's pic#14 clearly shows not.
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I had this problem with the stock downpipe, when I got everything fabricated properly and used chain reinforced mounts. No more height issues at all from the exhaust
      The issue is mostly that it is a dual section exhaust, that is the part that will hit most of the time from the flanges just past the downpipe
      1996 S2 ABY Silver
      • hunker7
        • Mar 2014
        • 3487
        Not having new exhaust done anytime soon unfortunately. But I will check it tomorrow and get some new mounts and hope it fixes the issue.
        '93 Audi UrS4 Avant
        '15 Audi A7 quattro 3.0 TDI
        • hunker7
          • Mar 2014
          • 3487
          These are not chain reinforced I assume?
          http://m.ebay.co.uk/itm/EXHAUST-MOUN...%257Ciid%253A1
          '93 Audi UrS4 Avant
          • John.
            • 2615
            No.
            This is...... http://www.candrenterprises.co.uk/sh...s-with-chains/
            • hunker7
              • Mar 2014
              • 3487
              #21
              Bloody hell they're steep ..and I need 3 of those what do I use for item 13 in Daves post, picture 2?
              '93 Audi UrS4 Avant
                Yup. Those are the ones John. Get what you pay for.
                • hunker7
                  • Mar 2014
                  • 3487
                  #23
                  So what do in replace the item 13 with? As the one I have now is *****.
                  '93 Audi UrS4 Avant
                    893253147F
                    Doesn't take that much weight if your other hangers are working. It is designed to be a locator rather than a weight taker. "Keep your exhaust from sliding off the hanger" :
                    https://www.ecstuning.com/Search/893253147f/ES424620/
                    http://www.buycarparts.co.uk/oen/893253147f#
                    • hunker7
                      • Mar 2014
                      • 3487
                      #25
                      OK then, I can leave that as I replaced it recently. If I remember correctly it did take a lot of weight which means rest of them are bad. OK, I'll order 3 and hope that fixes my problem. Thanks for the help guys.
                      '93 Audi UrS4 Avant
                      • andy10v
                        • 5996
                        If you want to confirm it is hanger sag then jubilee clips or heavy cable ties will pull it up to check.
                        The cheap ebay ones stretch to about twice the length of the chain ones.
                        Sold ABY-stock
                        • hunker7
                          • Mar 2014
                          • 3487
                          #27
                          Received them today, and noticed that the hangers on the exhaust/car are too wide to fit new hangers? I guess I can just cut it to make it narrower?
                          '93 Audi UrS4 Avant
                          • Lago Blue
                            • Jul 2009
                            • 845
                            Hang us a picture
                            Perhaps you could post a photo of your current set-up where you are trying to install these alternatives?
