Hi Guys.
Question for those of you who have made a custom exhaust system for your cars. Doesn't matter if it's a B4 or a C4.
I'm doing an exhaust rebuild soon, to accomodate the 7200 turbo and going for a full stainless turboback 3 inch exhaust. It's going to be a straight pipe up until the end. At the end is what I cannot decide what to do. I'd like very much to keep the 2 exhaust pipe layout which fit right under the cut of the rear bumper, pretty much only for aesthetic reasons. Now the problem is that there are not any readily available back mufflers with 76mm inlet and 2x 76mm outlets. Because of that I'm most likely opting for a Magnaflow muffler with single 76mm inlet and single 100mm outlet. But it's possible to fit a Magnaflow resonator and just weld the outlets to it as I like.
So the question is, what would be better for maximum freeflowing exhaust, a single muffler or a single resonator? I'd like to make it once and leave it. Also, would a 76mm inlet and 2x 76mm outlet configuration work?
This is the muffler in question (or any similar ones) - http://adparts.eu/lv/auto/exhaust-sy...ies-14835.html
Here's a bunch of resonators - http://adparts.eu/lv/auto/exhaust-sy...76mm_3_00.html
This is what I have now -
Lots of BTDTs where people *think* that they can get away without a center muffler and then find out about the drone.
How big are the tailpipes at the very end? 2x76mm?
The stock exhaust is good for 400 hp, the Stromung is good for well over 600 hp based on that car in the Youtube video - which was making well over 600 hp crank.
