Does anyone know of a Wastegate adapter, to go from OEM flange to v-band or anything?
Wastegate adapter?
Tags: None
I have a Tial wastegate and I just tig welded a 1.75" vband straight onto it, using an adapter would take up a lot of room IMHO.Last edited by gnutz2; 11 September 2016, 08:18.The ONLY S2 Golf!
10.42@138mph
https://m.youtube.com/watch?v=0wnkkOfFpXg -
The ONLY S2 Golf!
10.42@138mph
https://m.youtube.com/watch?v=0wnkkOfFpXgComment
There would be plenty of room if you switch stock WG to a Tial MVR, so a tiny adapter will fit no problem. This if you dont wan't to destroy your expencive manifold.
BMW 740iA e38 - ProjectComment
I don't think space should be an issue; the wastegate and heat sync are > 180mm in height.
Maybe I'm thinking about this wrong, but I was hoping to make downpipe fabrication a little easier. The flex-pipe on the stock setup seems to be a major limiting factor. Like everything has to be built around that piece.
from wagner to stock position and stock downpipe
