3" exhaust pipe over rear axle ???
  • nervas
    • 357
    • Country: Lithuania
    I would like to install 3" exhaust pipe from turbo till the end with one silencer (seperate WG somewhere under the car) so, tha main problem I think is to fit up and over rear axle, there is pretty tight. Maybe you have some pictures or experience fiting there 3"?
    Xtra Racing
    • 12431
    yeah I have taken quite a few of my install and it was a PITA. Make sure you got somewhere that spends their time fitting it I had to take mine back to have it fixed over 7 times.
    It has been modified since these pictures removing the first silencer but the other two are still fitted.
    • nervas
      • 357
      Yes I think, that install is PITA.
      And when you are driving, is there any sounds of exhaust hitting rear axle?
      Xtra Racing
      • WabTheKing
        • May 2004
        • 2567
        i spaced my sub frame down by 20mm to add a bit more clearance, its never dragged on the drive shaft and its been on bout 9months, spacer gives you that extra bit of breathing space when making it aswell, i only have one box aswell 12"x8"x4" i think and that sits just before the rear diff
        regards
        will
        • Dutch_RsBlueS2
          • Sep 2003
          • 285
          Jeffer and i just fitted a 3" system and it fitted well, we didn`t lowered the subframe, we had around 1,5 cm aboven and under clearance.
          I can make some pictures of this if you want i have some pictures of the whole system in my project progress thread.
          let me know,
          Cees
          • nervas
            • 357
            let me know,
            Cees
            it would be very nice, to see some details of rear diff and 3" pipes
            Xtra Racing
              • 12431
              It doesnt hit the rear axle but it is very close. If could do with moving back slightly to give better clearance over the drive shaft but I have left that for now until I have money to afford to get it changed again but it functions ok.
              • Audi_CQ
                • 940
                • Country: Norway
                I've got 3" and there are no clearance problems at all Take some time to get it right, but it's not difficult.
                Cheers,
                Roger
                • s2-1.5bar
                  • Sep 2004
                  • 193
                  • Home: Lithuania Current: United Kingdom
                  Its possible-I got 3" on mine-clearance very tight, but possible.
                  Regards
                  Andy
                  • S2sedan
                    • Aug 2004
                    • 189
                    Just stealing your thread, I have a T04E, with RS2 Hot side, I`m using the RS2 Downpipe, would be better to run 3'' back. I`m not going to change my downpipe right know ... just want to know if will bring any benefit if I change downpipe back.
                    best Eduardo.
                    S2 Limo sold !!!
                    M5 E34 with some mods in the garage
                    sorry, but much happeir now !
