So I've a query with the RS2 IM fitted to my engine that I've just put back into the car, I'm connecting all up and the two vac pipes pink and green with back rubber pipes go onto IM nipples at rear ? My old ABY IM had two and the RS2 IM has only one, looks like other has been removed and hole filled. Whats best way round this ? T into other one ? Ta
Rs2 IM query
Tags: None
T or Y piece will work. I run lpg and have 2 outputs feeding 7 inputs all with t pieces. Or you can drill and tap another hole and use something like this. That's what I did when I broke DV vacuum output at the front of the manifold.
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDI -
Cool, cheers just was fitting all electrics and pipes at the back of the head and couldn't suss out where it went lol !...Comment
