firend of mine has just bought his urs4 over, no boost whatsoever. Its blown the small vacuum pipe of the dump valve. When blipping the throttle theres is a metallic screeching noise coming from the flexi tub going from the wastegate pipe to the down pipe. Im guessing somethings shredded itself and is causing a blockage. No nasty noises coming from the turbo or any sort of smoke put of the exhaust whatsoever. Minimal axial play in the turbo coldside.
Any ideas? what could be in the flexi pipe? i thought possible cat, simlair to fat audi 80?
any suggestions will be glady received, going to let it cool down then take the flexi section off to have a look.
Gav
Gav
Did you know that you can buy Samco hoses for the S4? About £220 for the set (3 hoses) last time I looked which is way cheaper than the standard ones from Audi! S6 is the same as long as it's pre '98. AAN engine code and C4 chassis!
